Marlin to Sav MK1 January 29, 2018 06:58AM |
Re: Marlin to Sav MK1 January 29, 2018 07:39AM |
Re: Marlin to Sav MK1 January 29, 2018 07:48AM |
Dust
Its failing at the compile step, there is no image to flash to anything yet.
Did you install the Teensyduino ?
Did you install the SAV MKI files?
Did you select SAV MKI as the board type?
Did you set motherboard = "BOARD_SAV_MKI" in your configuration.h?
where exactly are you getting this new marlin from?
Re: Marlin to Sav MK1 January 30, 2018 05:37AM |
Re: Marlin to Sav MK1 January 30, 2018 06:22AM |
menu.usb=USB Type menu.speed=CPU Speed menu.keys=Keyboard Layout usbtsav.name=[usbtinyisp]SAV-MkI usbtsav.upload.using=usbtinyisp usbtsav.upload.maximum_size=131072 usbtsav.build.mcu=at90usb1286 usbtsav.build.fcpu=16000000L usbtsav.build.core=teensy usbtsav.build.usbtype=USB_SERIAL usbtsav.build.keylayout=US_ENGLISH usbtsav.build.warn_data_percentage=94 usbtsav.build.toolchain=avr/bin/ usbtsav.build.command.gcc=avr-gcc usbtsav.build.command.g++=avr-g++ usbtsav.build.command.ar=avr-ar usbtsav.build.command.objcopy=avr-objcopy usbtsav.build.command.objdump=avr-objdump usbtsav.build.command.size=avr-size usbtsav.build.flags.common=-g -Wall -ffunction-sections -fdata-sections usbtsav.build.flags.dep=-MMD usbtsav.build.flags.optimize=-Os usbtsav.build.flags.cpu=-mmcu=at90usb1286 usbtsav.build.flags.defs=-DTEENSYDUINO=141 -DARDUINO_ARCH_AVR usbtsav.build.flags.cpp=-fno-exceptions -felide-constructors -std=gnu++11 usbtsav.build.flags.c= usbtsav.build.flags.S=-x assembler-with-cpp usbtsav.build.flags.ld=-Wl,--gc-sections,--relax usbtsav.build.flags.ldspecs= usbtsav.build.flags.libs=-lm usbtsav.build.serial_number=true cdcsavD.name=[BootloaderCDC]SAV-MkI_RevD cdcsavD.upload.protocol=avr109 cdcsavD.upload.maximum_size=122048 cdcsavD.build.mcu=at90usb1286 cdcsavD.build.fcpu=16000000L cdcsavD.build.core=teensy cdcsavD.upload.speed=115200 cdcsavD.build.usbtype=USB_SERIAL cdcsavD.build.keylayout=US_ENGLISH cdcsavD.build.warn_data_percentage=94 cdcsavD.build.toolchain=avr/bin/ cdcsavD.build.command.gcc=avr-gcc cdcsavD.build.command.g++=avr-g++ cdcsavD.build.command.ar=avr-ar cdcsavD.build.command.objcopy=avr-objcopy cdcsavD.build.command.objdump=avr-objdump cdcsavD.build.command.size=avr-size cdcsavD.build.flags.common=-g -Wall -ffunction-sections -fdata-sections cdcsavD.build.flags.dep=-MMD cdcsavD.build.flags.optimize=-Os cdcsavD.build.flags.cpu=-mmcu=at90usb1286 cdcsavD.build.flags.defs=-DTEENSYDUINO=141 -DARDUINO_ARCH_AVR cdcsavD.build.flags.cpp=-fno-exceptions -felide-constructors -std=gnu++11 cdcsavD.build.flags.c= cdcsavD.build.flags.S=-x assembler-with-cpp cdcsavD.build.flags.ld=-Wl,--gc-sections,--relax cdcsavD.build.flags.ldspecs= cdcsavD.build.flags.libs=-lm cdcsavD.build.serial_number=true cdcsav.name=[BootloaderCDC]SAV-MkI_RevD.1 cdcsav.upload.protocol=avr109 cdcsav.upload.maximum_size=125952 cdcsav.build.mcu=at90usb1286 cdcsav.build.fcpu=16000000L cdcsav.build.core=teensy cdcsav.upload.speed=115200 cdcsav.build.usbtype=USB_SERIAL cdcsav.build.keylayout=US_ENGLISH cdcsav.build.warn_data_percentage=94 cdcsav.build.toolchain=avr/bin/ cdcsav.build.command.gcc=avr-gcc cdcsav.build.command.g++=avr-g++ cdcsav.build.command.ar=avr-ar cdcsav.build.command.objcopy=avr-objcopy cdcsav.build.command.objdump=avr-objdump cdcsav.build.command.size=avr-size cdcsav.build.flags.common=-g -Wall -ffunction-sections -fdata-sections cdcsav.build.flags.dep=-MMD cdcsav.build.flags.optimize=-Os cdcsav.build.flags.cpu=-mmcu=at90usb1286 cdcsav.build.flags.defs=-DTEENSYDUINO=141 -DARDUINO_ARCH_AVR cdcsav.build.flags.cpp=-fno-exceptions -felide-constructors -std=gnu++11 cdcsav.build.flags.c= cdcsav.build.flags.S=-x assembler-with-cpp cdcsav.build.flags.ld=-Wl,--gc-sections,--relax cdcsav.build.flags.ldspecs= cdcsav.build.flags.libs=-lm cdcsav.build.serial_number=true
Re: Marlin to Sav MK1 January 30, 2018 10:30AM |
Re: Marlin to Sav MK1 February 05, 2018 07:03AM |
Re: Marlin to Sav MK1 February 05, 2018 08:14AM |
Re: Marlin to Sav MK1 February 05, 2018 08:22AM |
Re: Marlin to Sav MK1 February 06, 2018 02:55PM |
Re: Marlin to Sav MK1 February 08, 2018 02:17PM |
Warning: Board arduino:avr:usbtsav doesn't define a 'build.board' preference. Auto-set to: AVR_USBTSAV Warning: Board arduino:avr:cdcsav doesn't define a 'build.board' preference. Auto-set to: AVR_CDCSAV Warning: Board arduino:avr:cdcsavD doesn't define a 'build.board' preference. Auto-set to: AVR_CDCSAVD Warning: Board teensy:avr:cdcsavD doesn't define a 'build.board' preference. Auto-set to: AVR_CDCSAVD Warning: Board teensy:avr:usbtsav doesn't define a 'build.board' preference. Auto-set to: AVR_USBTSAV Warning: Board teensy:avr:cdcsav doesn't define a 'build.board' preference. Auto-set to: AVR_CDCSAV
