Z-Offset being ignored. Marlin V1, Tronxy P802MA, Melzi.
Posted by Billythakid
February 02, 2018 05:56PM
I recently flashed the 'P802MA_8_MarlinV1_Melzi_ADCKey' firmware onto my Tronxy P802MA 3D printer. It has a Melzi 3.0 V3 board.
I then fitted a Tronxy XY-08N Z-probe and connected it to the Z Endswitch slot on the board.
The firmware works and the Z-probe glows red when it is close to the bed after homing and then stops like it's supposed to.
Albeit, the nozzle is a few MM's from the bed every time I home the Z-axis and changing the Z-Offset via the EEPROM and Pronterface software doesn't seem to work.
Does anybody have any advice please?
Thanks, Bill.
Re: Z-Offset being ignored. Marlin V1, Tronxy P802MA, Melzi.
February 02, 2018 06:49PM
My 3D Printer stops nozzle at 10.5mm above the bed - I lower 10.5mm it to set nozzle height = zero. Z-Offset -0.5 plus Z_Clearance 10mm = 10.5mm
Let's see if this will help
Configuration.h
#define Z_PROBE_OFFSET_FROM_EXTRUDER -0.5 // Z offset: -below +above [the nozzle]
#define Z_CLEARANCE_DEPLOY_PROBE 10 // Z Clearance for Deploy/Stow
#define Z_CLEARANCE_BETWEEN_PROBES 5 // Z Clearance between probe points
Configuration_adv.h
#define ADVANCED_PAUSE_FEATURE
... #define PAUSE_PARK_Z_ADD 10 // Z addition of hotend (lift)
February 03, 2018 06:48AM
Thanks for your response Clif.
I will try this when I get home from work and will report back with the result.
Thanks, Bill.
Roberts_Clif
Configuration.h
Configuration_adv.h
