Not seeing any other errors or a log file? When I click verify this is everything that comes up in the message center thing.
"In file included from sketch\thermistortables.h:80:0,
from sketch\temperature.h:30,
from sketch\Marlin_main.cpp:250:
sketch\thermistortable_13.h:48:1: warning: narrowing conversion of '3.20640015e+2' from 'double' to 'const short int' inside { } [-Wnarrowing]
sketch\thermistortable_13.h:48:1: warning: narrowing conversion of '3.71040009e+2' from 'double' to 'const short int' inside { } [-Wnarrowing]
sketch\thermistortable_13.h:48:1: warning: narrowing conversion of '4.27359985e+2' from 'double' to 'const short int' inside { } [-Wnarrowing]
sketch\thermistortable_13.h:48:1: warning: narrowing conversion of '4.99679993e+2' from 'double' to 'const short int' inside { } [-Wnarrowing]
sketch\thermistortable_13.h:48:1: warning: narrowing conversion of '5.84320007e+2' from 'double' to 'const short int' inside { } [-Wnarrowing]
sketch\thermistortable_13.h:48:1: warning: narrowing conversion of '6.84e+2' from 'double' to 'const short int' inside { } [-Wnarrowing]
sketch\thermistortable_13.h:48:1: warning: narrowing conversion of '8.10880005e+2' from 'double' to 'const short int' inside { } [-Wnarrowing]
sketch\thermistortable_13.h:48:1: warning: narrowing conversion of '9.6352002e+2' from 'double' to 'const short int' inside { } [-Wnarrowing]
sketch\thermistortable_13.h:48:1: warning: narrowing conversion of '1.15247998e+3' from 'double' to 'const short int' inside { } [-Wnarrowing]
sketch\thermistortable_13.h:48:1: warning: narrowing conversion of '1.38943994e+3' from 'double' to 'const short int' inside { } [-Wnarrowing]
sketch\thermistortable_13.h:48:1: warning: narrowing conversion of '1.64464001e+3' from 'double' to 'const short int' inside { } [-Wnarrowing]
sketch\thermistortable_13.h:48:1: warning: narrowing conversion of '1.99135999e+3' from 'double' to 'const short int' inside { } [-Wnarrowing]
sketch\thermistortable_13.h:48:1: warning: narrowing conversion of '2.41632007e+3' from 'double' to 'const short int' inside { } [-Wnarrowing]
sketch\thermistortable_13.h:48:1: warning: narrowing conversion of '2.92576001e+3' from 'double' to 'const short int' inside { } [-Wnarrowing]
sketch\thermistortable_13.h:48:1: warning: narrowing conversion of '3.53152002e+3' from 'double' to 'const short int' inside { } [-Wnarrowing]
sketch\thermistortable_13.h:48:1: warning: narrowing conversion of '5.07135986e+3' from 'double' to 'const short int' inside { } [-Wnarrowing]
sketch\thermistortable_13.h:48:1: warning: narrowing conversion of '7.15472021e+3' from 'double' to 'const short int' inside { } [-Wnarrowing]
sketch\thermistortable_13.h:48:1: warning: narrowing conversion of '9.44975977e+3' from 'double' to 'const short int' inside { } [-Wnarrowing]
sketch\thermistortable_13.h:48:1: warning: narrowing conversion of '1.179696e+4' from 'double' to 'const short int' inside { } [-Wnarrowing]
sketch\thermistortable_13.h:48:1: warning: narrowing conversion of '1.37243203e+4' from 'double' to 'const short int' inside { } [-Wnarrowing]
sketch\thermistortable_13.h:48:1: warning: narrowing conversion of '1.50323203e+4' from 'double' to 'const short int' inside { } [-Wnarrowing]
sketch\thermistortable_13.h:48:1: warning: narrowing conversion of '1.57764805e+4' from 'double' to 'const short int' inside { } [-Wnarrowing]
sketch\thermistortable_13.h:48:1: warning: narrowing conversion of '1.61392002e+4' from 'double' to 'const short int' inside { } [-Wnarrowing]
from sketch\configuration_store.cpp:184:
from sketch\endstops.cpp:30:
from sketch\planner.cpp:63:
from sketch\stepper.cpp:51:
from sketch\temperature.cpp:28:
from sketch\ultralcd.cpp:31:
from sketch\utility.cpp:25:
Sketch uses 116216 bytes (45%) of program storage space. Maximum is 253952 bytes.
Global variables use 4602 bytes (56%) of dynamic memory, leaving 3590 bytes for local variables. Maximum is 8192 bytes.
