"Inverted" ABL Correction Matrix? February 12, 2018 08:26PM |
Send: M420 V Recv: Bed Level Correction Matrix:+1.000000 +0.000000 -0.000136 Recv: -0.000000 +1.000000 -0.000970 Recv: +0.000136 +0.000970 +1.000000 Recv: echo:Bed Leveling On Recv: ok
Send: M115 Recv: FIRMWARE_NAME:Marlin 1.1.8 (Github) SOURCE_CODE_URL:[github.com] PROTOCOL_VERSION:1.0 MACHINE_TYPE:Thinger EXTRUDER_COUNT:1 UUID:cede2a2f-41a2-4748-9b12-c55c62f367ff Recv: CapThanks.ERIAL_XON_XOFF:0 Recv: Cap:EEPROM:1 Recv: Cap:VOLUMETRIC:1 Recv: Cap:AUTOREPORT_TEMP:1 Recv: Cap
ROGRESS:0 Recv: Cap
RINT_JOB:1 Recv: Cap:AUTOLEVEL:1 Recv: Cap:Z_PROBE:1 Recv: Cap:LEVELING_DATA:1 Recv: Cap:BUILD_PERCENT:0 Recv: Cap
OFTWARE_POWER:0 Recv: Cap:TOGGLE_LIGHTS:0 Recv: Cap:CASE_LIGHT_BRIGHTNESS:0 Recv: Cap:EMERGENCY_PARSER:0 Recv: ok Send: M155 S2 Recv: ok
Re: "Inverted" ABL Correction Matrix? February 13, 2018 06:50AM |
Re: "Inverted" ABL Correction Matrix? February 13, 2018 12:03PM |
Re: "Inverted" ABL Correction Matrix? February 13, 2018 12:05PM |
Re: "Inverted" ABL Correction Matrix? February 13, 2018 12:48PM |
Roxy
You may be running into this issue: [github.com]
The reason for the flaw is not currently known. You might want to switch to a different bed leveling system until this is fixed.
Re: "Inverted" ABL Correction Matrix? February 13, 2018 12:54PM |
bcsteeve
obewan
What is the new bed material, and what type of probe are you using ?
Glass vs glass... just a different sheet. Using capacitive sensor.
Re: "Inverted" ABL Correction Matrix? February 13, 2018 01:09PM |
obewan
bcsteeve
obewan
Are capacitive proximetry sensors accurate enough with glass ?
Is it possible the capacitive sensor is actually getting reflections off your alluminium bed.
