Teensy 3.5/3.6 pin assignment status
Posted by daPhoosa
April 25, 2018 05:25PM
Hello,
I am in the process of designing a 3D printer board that is driven by the Teensy 3.5/3.6 micro controller. I would like to make sure it is compatible with Marlin. In reviewing the current pin map (https://github.com/MarlinFirmware/Marlin/blob/bugfix-2.0.x/Marlin/src/pins/pins_TEENSY35_36.h), I have the following questions:
1) Is this pin mapping set in stone?
2) Is it intentional that the diagram and the actual pin definitions don't match?
3) Are there boards released or being developed that use it?
I have some thoughts and suggestions, but I don't want to break anyone elses work. My project is fairly maleable at this point but I'd like to make sure some of the communication peripherals are not blocked. If the current set-up is locked, I'll just make my own board type for Marlin once my board is complete.
Thanks,
Phillip
Re: Teensy 3.5/3.6 pin assignment status
April 26, 2018 08:50AM
You make your own pins_{your_board_name_here}.h to suite your board
Then you dont break what ever they are working on with pins_TEENSY35_36.h
April 26, 2018 09:48AM
Dust
That is reasonable. I wanted to avoid unneeded board additions, but making my own pin definition is probably the best way to avoid conflicts. Thanks.
