X, Y and Z axis not assigned
May 04, 2018 04:13AM
Hi all. I have had a string of problems trying to get my GT2560 and Geeetech Aluminium Prusa i3 working but have gotten so close. I found someone who had the same config as mine but with custom firmware here >[www.geeetech.com]
The problem is, they have BLTouch enabled and I don't have that. If I upload the firmware anyway, it looks like its running fine but the x axis controlls the z axis and the y seems to be the only control that is working.
It's mentioned to comment out the touch part of the code but all I get are errors when trying to compile again! Maybe this is interfering with the pins??
This is the firmware I downloaded: [www.geeetech.com]
I'm using the latest Arduino IDE on Windows 10 (Version 1 did not want to compile at all).
Edited 1 time(s). Last edit at 05/04/2018 04:14AM by Volume3k.
Re: X, Y and Z axis not assigned
May 04, 2018 05:26AM
The firmware you linked has a ultimaker board defined in the config.h, i think this has a totally different pinout than a GT2560.
May 05, 2018 04:01AM
So the boards.h I have does not include GT2560. The newer version of Marlin does however, so I copied over boards.h from there and the pins file for my GT2560.
I changed the motherboard to GT2560 in config.h file but now when I go to compile it says;
* Require some kind of probe for bed leveling and probe testing
#if HAS_ABL
#if ENABLED(AUTO_BED_LEVELING_UBL)
#error "Unified Bed Leveling requires a probe: FIX_MOUNTED_PROBE, BLTOUCH, SOLENOID_PROBE, Z_PROBE_ALLEN_KEY, Z_PROBE_SLED, or Z Servo."
#else
#error "Auto Bed Leveling requires one of these: PROBE_MANUALLY, FIX_MOUNTED_PROBE, BLTOUCH, SOLENOID_PROBE, Z_PROBE_ALLEN_KEY, Z_PROBE_SLED, or a Z Servo."
#endif
#endif
The original poster said to comment out BLtouch if not using but every time I try this it doesn't work. There's plenty of youtube videos on how to get BLtouch working but can't disable it in the code I don't use auto bed leveling?
Edited 1 time(s). Last edit at 05/05/2018 04:05AM by Volume3k.
May 05, 2018 04:46AM
I have solved this problem by finding another firmware, the 1.1.8 firmware now uploads to the board fine. Thanks for helping anyway.
