Hi/Hello,
I need your help. I was trying to set up auto leveling on my CNC with Marlin. As you can see at [
drive.google.com] It seems the Clearance does not work, because if there is some protrusion the probe (drill) crashes on the bed. I used the G28 to get all the axes at home and then the G29 to measure the bed. So there should not be scratches from the drill on the bed.
Could someone help me? My configuration.h attached.
Thank you in advance
Edited 1 time(s). Last edit at 05/06/2018 03:56AM by TheONE59.
