Auto leveling - traveling during probing
Posted by TheONE59
May 05, 2018 11:44AM
Hi/Hello,
I need your help. I was trying to set up auto leveling on my CNC with Marlin. As you can see at [drive.google.com] It seems the Clearance does not work, because if there is some protrusion the probe (drill) crashes on the bed. I used the G28 to get all the axes at home and then the G29 to measure the bed. So there should not be scratches from the drill on the bed.
Could someone help me? My configuration.h attached.
Thank you in advance
Edited 1 time(s). Last edit at 05/06/2018 03:56AM by TheONE59.
open | download - Configuration.h (63 KB)
Re: Auto leveling - traveling during probing
May 05, 2018 09:35PM
It looks like it is moving nicely... But what is it supposed to be doing? Are you milling a part? Are you homing the machine? Are you probing the bed?
It is not clear what we are looking at.
May 06, 2018 03:53AM
yes, it's moving nicely, but with no z hop safe moving position, so if there is some protrusion the probe (drill) crashes on the bed. I used the G28 to get all the axes at home and then the G29 to measure the bed. So there should not be scratches from the drill on the bed.
Thanks
