Mesh leveling goes off of bed May 27, 2018 12:03PM |
Re: Mesh leveling goes off of bed May 27, 2018 02:55PM |
Re: Mesh leveling goes off of bed May 27, 2018 03:58PM |
Re: Mesh leveling goes off of bed May 27, 2018 05:54PM |
Re: Mesh leveling goes off of bed May 27, 2018 05:55PM |
Re: Mesh leveling goes off of bed May 27, 2018 06:20PM |
Roberts_Clif
Lets see if we can make some distance measurements. (they don't have to be exact but close would be good.)
Can you move the XY and Z Axis using the LCD manually.
Lets start with 2 inches (50.8mm)
Set any start location using masking tape mark the position of the nozzle.
Using the LCD move the nozzle 50.8mm and mark the distance then measure how far it moved.
Is the measured distance and the display distance approximately same.
Re: Mesh leveling goes off of bed May 27, 2018 06:23PM |
obewan
#define DEFAULT_AXIS_STEPS_PER_UNIT {200, 200, 800, 280 }
What stepper drivers do you have fitted ?
How did you come by these settings, X Y steps seem rather high.
Re: Mesh leveling goes off of bed May 27, 2018 07:22PM |
Re: Mesh leveling goes off of bed May 28, 2018 10:26AM |
Roberts_Clif
I though you already had your configuration.h, asked if you had the three jumpers installed video showed. Should have just posted the Jumper Image.
Prusa calculator is here
And
Triffid Hunter's Calibration Guide
Would Need more information in order give you Default Axis numbers.
Lead screw diameter and Pitch - PITCH (distance of rise for one full rotation)
Belt Pitch and Gear number of teeth
Below I have numbers for all Nema 17 Leadscrew Pitch, a 20 tooth 2mm pitch belt driven Y-Axis and X-Axis for my Prusa Hic i3, and Extruder number
// Typical stepper motors have 200 steps per full step/rev = 1.8°/step, so 1/16 microstepping = STEPS_PER_REVOLUTION_E = 3200
// X-Y Axis 3200, / 20 tooth, / 2mm pitch Belt = 200*16 / 20 / 2 = 80 :: (STEPS_PER_REVOLUTION_X / IDLER_TEETH_X / BELT_PITCH_X)
// Z Axis 3200, / 1.25mm pitch leadscrew = 200*16 /1.25 = 2560 :: (STEPS_PER_REVOLUTION_Z / PITCH_OF_Z_ROD)
// Z Axis 3200, / 2mm pitch leadscrew = 200*16 /2 = 1600 :: (STEPS_PER_REVOLUTION_Z / PITCH_OF_Z_ROD)
// Z Axis 3200, / 4mm pitch leadscrew = 200*16 /4 = 800 :: (STEPS_PER_REVOLUTION_Z / PITCH_OF_Z_ROD)
// Z Axis 3200, / 8mm pitch leadscrew = 200*16 /8 = 400 :: (STEPS_PER_REVOLUTION_Z / PITCH_OF_Z_ROD)
// E-Axis 3200, / (11mm Gear OD * pi) :: (STEPS_PER_REVOLUTION_E * EXTRUDER_GEAR_RATIO / (PINCH_WHEEL_DIAMETER * PI))
Example of My Numbers which are a fairly common Prusa i3 number set.
#define DEFAULT_AXIS_STEPS_PER_UNIT { 80, 80, 400, 94.4962144 }
(Though we may have to calculate all numbers if none was provided with Anet A8 kit. unless we find some with the same setup you have)
What is the Anet A8 you have can look see if can find.
Re: Mesh leveling goes off of bed May 28, 2018 01:09PM |
Re: Mesh leveling goes off of bed May 28, 2018 02:00PM |
Roberts_Clif
Cura 14.07 release date 7/3/14
Printable Size 220*220*240mm
Movement Speed 300mm/s
T type lead screw M8*345 #1700100015 (looking at the image you have a (T8-8))
Anet3D
Re: Mesh leveling goes off of bed May 28, 2018 02:11PM |
Re: Mesh leveling goes off of bed May 28, 2018 02:48PM |
Roxy
When you made changes to:
Did you do a M502 and M500 to get the new values stored in EEPROM? If not... you won't see any changes.
Re: Mesh leveling goes off of bed May 28, 2018 09:20PM |
Re: Mesh leveling goes off of bed May 30, 2018 03:47PM |
