Dual X Carriage not working
Posted by linway
May 30, 2018 05:33PM
last month i build my dual x-carriage printer with Rumba board
i try to modify marlin bugfix-1.1.x, but it has some problem
1. x2 carriage look like move to left when homing
2. x2 filament cooling fan not working when printing
3. t0 is ok, but t1 hotend not working when printing
i also try older version of marlin, but it has more problem
is that i use wrong setting or is that bugs?
here is my configuration and configuration.adv
[drive.google.com]
any hints or tips will be very thankful
Edited 1 time(s). Last edit at 05/31/2018 02:13PM by linway.
Re: Dual X Carriage not working
June 06, 2018 10:03AM
I also ran into serious problems using a current Marlin build for Dual X. A two year old version i am using so far does work.
With the current release the X2 Carriage does not move at all and when X is homed only X1 moves and does so well beyond the X_MAX position, until it reverses and finaly homes.
Does anyone have a current Marlin version successfully running Dual X?
[www.bonkers.de]
[merlin-hotend.de]
[www.hackerspace-ffm.de]
October 01, 2018 12:38PM
Seems IDEX used RUMBA was X,Y,Z,E0,E1,X2.But it no work well even doesn't work at all.The older version 1.1.0.RC6 that direct define X2 can work well,and anyone knows how to use M218 to set z offset ?My set was M218 X305.2 Y0.5 Z0.2 R0 and used M605 S1.please give any advice.
October 01, 2018 12:49PM
Did you changed any pins.h about your RUMBA,if you doesn't changed it ,that you might have a wrong wiring.
