Can't figure out BLTouch offset
June 10, 2018 12:33AM
I cannot figure out how to get the leveling values produced by the BLTouch to register. I'm using a custom 3D printer and Marlin bugfix 2.0.x. This is what happens:
G28 to home printer
G29 and the four corners of the bed are measured.
echo: M420 S1 Z0.00
echo: G29 W I1 J1 Z2.43446
echo: G29 W I2 J1 Z2.16985
echo: G29 W I1 J2 Z3.25292
echo: G29 W I2 J2 Z1.50892
I start the print and the print head is about 4mm above the bed. So I assume its the
#define Z_PROBE_OFFSET_FROM_EXTRUDER 2.4 // Z offset: -below +above [the nozzle] Line 768 Configuration.h.
Just to test, I set this value to 10, so
#define Z_PROBE_OFFSET_FROM_EXTRUDER 10 // Z offset: -below +above [the nozzle]
I restart the print and again the nozzle is about 4mm above the bed.
Next, I change the M851 Z offset from -2.7 to -10.
EEPROM is enabled for sure. When I send M503 I get my updated values but they seem to have no effect.
I restart the print and again the nozzle is about 4mm above the bed. What value do I need to change to get the nozzle to adjust for this offset?
Thanks in advance.
Edited 1 time(s). Last edit at 06/10/2018 12:40AM by Jeffsg605.
Re: Can't figure out BLTouch offset
July 09, 2018 04:21PM
I'm not sure but maybe its the slicer. Please tell me your custom start gcode. Had a similar issue and i was able to fix it by modifying the start gcode. Or maybe you have set the offset in your slicer.
Edited 1 time(s). Last edit at 07/09/2018 04:22PM by Kutulu.
July 09, 2018 05:34PM
After doing a G29, send a G1 Z0 ,does the nozzle stop at Z0 or is it above/below the bed ?
July 09, 2018 08:14PM
After any change to the default settings... You need to do a M502 (to load the default settings) followed by a M500 (to save the updated settings).
If you don't do that... The behavior won't change because it keeps using the saved values in the EEPROM.
