Changing Flow Rate or Filament Diameter Doesn't Change Anything July 02, 2018 04:45PM |
Send: M503 Recv: echo: G21 ; Units in mm Recv: echo: M149 C ; Units in Celsius Recv: Recv: echo:Filament settings:Recv: echo: M200 D2.00 Recv: echo: Steps per unit: Recv: echo: M92 X80.00 Y80.00 Z2560.00 E365.30 Recv: echo:Maximum feedrates (units/s): Recv: echo: M203 X300.00 Y300.00 Z5.00 E25.00 Recv: echo:Maximum Acceleration (units/s2): Recv: echo: M201 X3000 Y3000 Z100 E10000 Recv: echo:Acceleration (units/s2): P R T Recv: echo: M204 P3000.00 R3000.00 T3000.00 Recv: echo:Advanced: S T B X Z E Recv: echo: M205 S0.00 T0.00 B20000 X20.00 Y20.00 Z0.40 E5.00 Recv: echo:Home offset: Recv: echo: M206 X0.00 Y0.00 Z0.00 Recv: echo :Auto Bed Leveling: Recv: echo: M420 S0Recv: echo:Material heatup parameters: Recv: echo: M145 S0 H180 B70 F0 Recv: echo: M145 S1 H240 B110 F0 Recv: echo: PID settings: Recv: echo: M301 P26.78 I1.76 D102.01 Recv: echo: M304 P192.39 I27.57 D335.70 Recv: echo:Z-Probe Offset (mm): Recv: echo: M851 Z-0.21
Re: Changing Flow Rate or Filament Diameter Doesn't Change Anything July 02, 2018 04:59PM |
Re: Changing Flow Rate or Filament Diameter Doesn't Change Anything July 03, 2018 03:01AM |
Re: Changing Flow Rate or Filament Diameter Doesn't Change Anything July 03, 2018 04:45AM |
Re: Changing Flow Rate or Filament Diameter Doesn't Change Anything July 03, 2018 01:58PM |
Re: Changing Flow Rate or Filament Diameter Doesn't Change Anything July 07, 2018 03:49PM |
