G26 Test Print
Posted by brucehvn
G26 Test Print
August 24, 2018 07:38AM
I guess I had one other question. When printing a G26 test print, what should it look like as far as extrusion width? Should the lines look smooshed? If I'm using a .4 nozzle, how wide should the lines be in the test print?
It might be good idea to show an image of a good test print with the docs.
Re: G26 Test Print
August 26, 2018 11:07PM
This pattern looks good: [github.com]
You can argue about how much overlap a first layer print should have. And what temperature it should go down at. But if you can print a pattern that looks like this.... You won't have any problems with your first layer.
And... You will be able to get good adhesion across 100% of your bed 100% of the time.
