My board is MKS_GEN_L v 1.0
I added PT100 thermistor with amp. board.
I changed the thermistor type at configuration.h to TEMP_SENSOR_0 20 (for PT100)
I changed in pins.h the connected PIN to TEMP_0_PIN 11 (analog port 11)
When I check the status of this analog PIN with M43 command, I see, that the value is there
PIN:65 PORT: K3(A11) unused/unknown Analog In=252 Input 0 with connected PT100
When I disconnect the thermistor, there is value Analog In=780
But the desk is still reading the former original thermistor port .
When I connect to this port the 100k thermistor, Im getting correct value
The Marlin just refuses to use the analog port 11.
I can not tell Marlin to read the analog port 11
What Im doing wrong?
Edited 1 time(s). Last edit at 08/30/2018 12:06PM by LacoD.
