Aloha :-)
For some days I try to load Marlin 1.1.9 (2.0.0) as firmware on my Arduino DUE with RADDS.
The following error message I get through the Arduino IDE:
In file included from sketch\HAL.h:33:0,
from sketch\MarlinConfig.h:39,
from sketch\G26_Mesh_Validation_Tool.cpp:27:
sketch\fastio.h:34:20: fatal error: avr/io.h: No such file or directory
#include <avr/io.h>
compilation terminated.
exit status 1
Fehler beim Kompilieren für das Board Arduino Due (Programming Port).
I have already tried the folder "avr/" including the "io.h" in different directories to copy. But no matter what I do, each time the same error message appears.
In the version 1.0.0 (which I use for years and which also works well) is "avr/io.h" does not exist. So I have no problems there.
Does any of you have a solution?
Greeting,
Chris
Edited 1 time(s). Last edit at 09/02/2018 04:37PM by EcoF83R.
