Z offset after homing
Posted by RC-CnC
September 08, 2018 04:36PM
Hi
Marlin 1.1.8
Anybody know how to offset z height to physically be 1mm above the mechanical endstop switch after homing
Re: Z offset after homing
September 08, 2018 05:08PM
If you are not using Z Clearance Deploy Probe you could possible use it.
#define Z_CLEARANCE_DEPLOY_PROBE 10 // Z Clearance for Deploy/Stow
I prefer clearance 10mm as you can see by my line of code above.
September 08, 2018 09:21PM
But I'm not using a probe of any kind
September 09, 2018 09:01AM
I used
#define Z_PROBE_OFFSET_FROM_EXTRUDER -0.5 // Z offset: -below +above [the nozzle]
And
With end-Stop Switch, and you should be able to.
September 09, 2018 08:54PM
Ohh I thought it was for use with a probe...I'll give it a try
September 09, 2018 09:05PM
Well even the first SN04-N Inductive probe used is nothing more the a NPN NO powered transistor switch with the ability to sense metal at a 5mm distance.
It was swapped in for my standard End-Stop Switch without any firmware changes to my Marlin firmware.
