babystepping z September 10, 2018 12:42PM |
Re: babystepping z September 18, 2018 10:32AM |
Re: babystepping z September 18, 2018 02:12PM |
Re: babystepping z October 02, 2018 06:19AM |
Roberts_Clif
I use babystepping from the LCD control It works great .
I print a skirt and adjust while watching for the perfect height. below I can see and change watching the numbers on the LCD.
I should change the Multiplicator to a higher number like 10, 2 is way to fine.
#define BABYSTEPPING
#if ENABLED(BABYSTEPPING)
#define BABYSTEP_XY // Also enable X/Y Babystepping. Not supported on DELTA!
#define BABYSTEP_INVERT_Z false // Change if Z babysteps should go the other way
#define BABYSTEP_MULTIPLICATOR 2 // Babysteps are very small. Increase for faster motion.
//#define BABYSTEP_ZPROBE_OFFSET // Enable to combine M851 and Babystepping
//#define DOUBLECLICK_FOR_Z_BABYSTEPPING // Double-click on the Status Screen for Z Babystepping.
#define DOUBLECLICK_MAX_INTERVAL 1250 // Maximum interval between clicks, in milliseconds.
// Note: Extra time may be added to mitigate controller latency.
#endif
Re: babystepping z October 02, 2018 07:29AM |
Re: babystepping z October 02, 2018 02:25PM |
Re: babystepping z October 02, 2018 02:26PM |
Roberts_Clif
OK here is my Marlin 1.1.5 shareable Link.
[drive.google.com]
This one is setup for Duel Extruders - Have not added second extruder yet so it is untested
[drive.google.com]
