Hi.
i've been wanting to remove my start gcode from the slicer in order to be able to use the same gcode file on multiple printers.
typically i can use the same temps and speeds, but the start up code differs in terms of tool cleaning and nozzle prime position.
So i would like to have the start g-code in firmware and maybe call a Gxxx or Mxxx to activate this start gcode.
that way it's possible to put the homing, probing , move Z, goto Xxx Yxx, extrude , or whatever the needs might be, everytime a print is started.
Does this functionality exist already ?
i've seen the Autostart, but this is only for power up,and requires an SD, and i want it to run every time i start a print (typically from SD)
and there's also the CUSTOM_USER_MENUS , but these have to be activated through the LCD.
Anybody did this already ?
