mintemp triggered heater_id:0
Posted by rflournoy
September 18, 2018 08:56PM
I have a REPRAP Prusa i3 running Marlin firmware. I just changed the extruder/hotend that came with the kit to a Tital Aero. When trying to print, the heatbed begins to warm up, but the hotend never begins to heat. I've made the changes to the firmware as required, but something isn't right. Any ideas?
Re: mintemp triggered heater_id:0
September 20, 2018 03:14PM
double check the wiring ?
which changes did you make in firmware ?
September 20, 2018 04:09PM
and what temperature does the hot end read at room temp?
I suspect new thermistor on hotend is not connected correctly.
September 24, 2018 12:03AM
Thank you. I had a couple of wires plugged into the wrong pin in that "spider web" of wires. It seems to be working now. smiling smiley
September 24, 2018 12:04AM
Thank you. The hot end was registering the same as the room temp. I had a couple of wires plugged into the wrong pin in that "spider web" of wires. It seems to be working now. smiling smiley
