It might very well be possible.
Are you using Marlin 1.1.9 or 2.0.X?
- For 1.1.9 - In file
Marlin_main.cpp - at the very bottom of the file
Replace:
idle();
With:
idle();
#if (HAS_POWER_SWITCH && HAS_HEATED_BED)
if (thermalManager.degBed() >= 150) { PSU_OFF(); }
#endif
- For 2.0.x - In file
Marlin.cpp - at the very bottom of the file
Replace:
idle();
With:
idle();
#endif
What ever version of Marlin you are using.
- you might want to test with setting the limit to for example 50,
- and turn on your bed, to go higher than 50
And see if the PSU gets turned off when the temp reaches 50*C
I have not tested the suggested code, beyond making sure that it can compile, so I will be interested to hear if this code actually does what you are requesting.
