reprap full graphic controller flickers/ lags when in SD menu October 02, 2018 05:20PM |
Re: reprap full graphic controller flickers/ lags when in SD menu October 08, 2018 09:02PM |
Re: reprap full graphic controller flickers/ lags when in SD menu October 08, 2018 09:08PM |
Re: reprap full graphic controller flickers/ lags when in SD menu October 09, 2018 03:25PM |
Re: reprap full graphic controller flickers/ lags when in SD menu October 09, 2018 03:26PM |
MrAlvin
You might need to map/test each pin in the ribbon connectors.
It might seem like it has been enough to "reverse the ribbon cables", but some pins within the ribbon cable sockets may actually be different than than your "old" LCD.
Not all clone manufactures follow the ReprapDiscount standard pin placement exactly in the ribbon cable. And you needing to reverse the cable, seems to indicate that they, for some odd reason, has made some "clever" changes. And now you need to discover what changes they might have made.
Re: reprap full graphic controller flickers/ lags when in SD menu October 09, 2018 03:27PM |
