Hi
I have a pretty odd problem. I have an elderly Mendel fitted with RAMPS 1.4 which has been out of use for a while, so I decided to give it a clean up and get it going again. As part of this I decided to upgrade the Marlin firmware, Slic3r, Pronterface etc.
Now the printer basically works - except for this issue affecting the Z motors*. Basically I can connect, move XYZ no problem but shortly after homing the Z motors begin to "tick" every second or so... it feels like they are being de-energised for short pulses. If I move the Z axis it repeatedly pauses, sometimes it squeals when it tries to restart.
The X & Y axis don't suffer - in fact they are quite happy moving while the Z axis is stuttering away.
I've used v1.1 and the latest bugfix. The old v1.0 is OK though.
Any ideas? I can put the old version back, although I'd like to update it if possible.
* Dual motors, but in parallel with a single driver. Also I don't have auto leveling enabled FWIW.
