Change extruder stepper...how to do it?
Posted by zonalimitatore
November 08, 2018 07:15AM
Hi guys.
I have gt2560 rev.b and my original extruder slot stop work.
I have 2 free slot for add extruders.
What i have to mod in firmware for work on 2nd slot?
Re: Change extruder stepper...how to do it?
November 08, 2018 09:20AM
Presuming you have tried swapping the stepper driver module and it not just a dead stepper driver...
You need to change the appropriate pins.h file for your controller.
Looks like motherboard is set to BOARD_ULTIMAKER for these boards, so this is a starting point.
Now depending if you have a older firmware or a newer firmware you have to look in different places
in older firmware everything was in pins.h, in newer they split it up into different files, looks like its pins_ULTIMAKER.h
If its one large pins.h file you need to fine the correct section, search for "Ultimaker pin assignment" directly under that you will find the pins for your hardware
you will find something like
#define E0_STEP_PIN 43
#define E0_DIR_PIN 45
#define E0_ENABLE_PIN 41
#define E1_STEP_PIN 49
#define E1_DIR_PIN 47
#define E1_ENABLE_PIN 4
simply swap all the E0 and E1 Pins over and the extruder will start to use the E1 socket.
November 08, 2018 09:28AM
Yes...I try to swap the pin assignment,but temp sign -14°
I search in motherboard's datasheet and assign relative pin,but still -14°
I'm on 2.0 now,and I cant move estruder
Little question....I've to swap the molex connector too or keep it in original place?
November 08, 2018 11:11AM
yes you have to move the stepper molex connector, and you have to move the stepper driver if that slot is empty
temperature has nothing to do with stepper motors...
November 08, 2018 12:04PM
Ok....This is my situation.
I have to solder the 12 pin,cause the board haven't....
It's right like this?
Now I've only to find the temp pin?
open | download - IMG_20181108_175727.jpg (681.2 KB)
November 08, 2018 10:01PM
Ah I see... non standard connectors for extruders where everything is grouped together... didn't notice this originally.
yes you will have to solder in a new header
after quite a bit of searching I found this circuit diagram [github.com]
and new firmware [github.com]
with is own boards file [github.com]
but this doesn't tell you directly what the thermistor pins are
name, phiscal pin,  arduino pin
t2       86    analog 11
t bed    87    analog 10
t1       88    analog 9
t0       89    analog 8
So it one of the above 4
Edited 1 time(s). Last edit at 11/08/2018 10:02PM by Dust.
November 09, 2018 01:46AM
Well I did it!!!
I have to edit and delete the string of old extruder and add a9 for temp sensor.
Now work all
Thanks for help
November 09, 2018 10:33AM
It's normal that when I switch on the printer,give me -14C° on extruder? Bed give me 19(room temp) and early the same on bed
Yesterday when I try and test give me the right temp.
Today,work anyway,but start -14C°
I don't know if this issue give a problem with the real extrusion temp
November 10, 2018 06:29PM
Seems to be solved.....Now don't give me -14C° on start winking smiley
