Servo not moving to correct angle
Posted by foul_owl
November 10, 2018 07:00PM
I have my stow / deploy angles set to 70 / 140 respectively.
However, when the actual autolevel process is running, the deploy angle looks closer to 120.
I have checked this by manually setting the angle and comparing to when the autoleveling process is running, it is definitely not correct when autoleveling is going.
This issue has actually caused the printer to descend with the servo arm at an angle, causing the button to miss and the servo arm to break. I had to replace both the arm and the servo.
Is this a Marlin bug?
Re: Servo not moving to correct angle
December 05, 2018 03:45AM
Bump. Still having this issue unfortunately.
December 05, 2018 04:04AM
Ok I feel stupid, but good to document for anyone else that runs into this issue.
SERVO_DELAY { 500 }
fixed the issue for me.
I didn't realize there was a timeout variable here.
