How Do I Enable the M140 Heating Bed Option?
Posted by chiques
December 22, 2018 11:41PM
I am using Marlin 1.1.9. I am trying to heat my bad using the 'M140 S60' command but it's not working. When I enter this in Pronterface I get:
Setting bed temperature to 60.000000 degrees Celsius.
echo:Unknown command: "M140 S60.0"
Does anyone know how to enable this in the firmware?
Re: How Do I Enable the M140 Heating Bed Option?
December 23, 2018 01:41AM
HAS_HEATED_BED has to be defined
this is true when HAS_TEMP_BED && HAS_HEATER_BED is defined
HAS_TEMP_BED is true when HAS_TEMP_ADC_BED
HAS_HEATER_BED is true is PIN_EXISTS(HEATER_BED)
So
Either you have not defined a pin for your heated bed, or you have not defined a pin for your bed thermistor
December 23, 2018 01:08PM
Dust
So
Hello Dust,
None of these variables are in my current Configuration.h or Configuration_adv.h files. Do I just add them?
December 23, 2018 01:15PM
chiques
Dust
So
Hello Dust,
Disregard my question. I found the problem.
#define TEMP_SENSOR_BED 0
is set to '0'
Once I set it to '1' it enabled the LCD icon and the error no longer exists.
Thanks for the hint!
