Hello,
I've searched through the forum and can't find anyone who's running into the same issue as me. I've just finished building a CoreXY. Initially, I had an MKS Gen 1.4 with DRV8825's throughout. I wanted to install some TMC 2100's to replace my X/Y Movement, and I'm running into an issue where all my movement's are twice what they should be; 1mm is moving 2mm, 10/20, 100/200, etc.. I've adjusted the steps/mm in the firmware with no change - I've also played with the microstepping jumpers on the board. All with no results. I've closed the solder pads between CFG1 and GND as I wanted to run in spreadcycle mode. I've also tried in stealthchop with the same result..
can anyone offer some insight into why this is happening?
Thank you very much in advance,
~C.
