X axis end stop not stopping.
Posted by Paul G
January 24, 2019 03:49PM
Hi. I have just built a Anet a8-m dual printer. The x axis end stop was working with the original software. I have changed to Marlin and used a configuration I found for the KFB 2.0 control board. Now the x axis is not stopping at the switch when I home the x axis. I have tried checking all the code variables but to no avail. The Y and Z axis both work OK. I have attached the config uration.h file (not sure if this the correct method. Hope someone can help
Thanks
Paul
Hi All. Found it. In the Pins_KFB_2.h file the X_min_pin has been changed to 2 from 3. Don't know why but I've changed to an equivalent board with in 3 and it works now
Paul
Edited 1 time(s). Last edit at 01/24/2019 05:49PM by Paul G.
open | download - Configuration.h (65 KB)
