Goodmorning everyone! I decided to build my first 3D printer. I bought a 12864 Full Graphic Smart Controller LCD and an sd card extension. I have the following problem:
I insert the sd card inside the slot of the display, and in the home tells me sd card inserted while in the menu tells me Print from sd card. So the sd card display slot works great.
When I connect the extension sd card to the display and insert the sd card in the extension, in the home tells me: SD card inserted, while in the menu: SD card not present.
I use a micro sd card (with adapter) Kingston 32gb, formatted in FAT32. Also I tried to connect the sd card extension to the computer, and it works properly. So I excluded that it was a problem with the extension.
Can someone with a good heart, or who has had the same problem with me, help me?
Firmware: Marlin 1.1.9
Shield: Ramps 1.4
open |
download -
(129.5 KB)
