Marlin 2.0 and STM32F103C8 February 12, 2019 09:40PM |
Re: Marlin 2.0 and STM32F103C8 February 13, 2019 12:22AM |
Admin Registered: 15 years ago Posts: 7,337 |
Re: Marlin 2.0 and STM32F103C8 February 13, 2019 01:02AM |
PLATFORM: ST STM32 > STM32F103CB (20k RAM. 128k Flash) HARDWARE: STM32F103CBT6 72MHz 20KB RAM (128KB Flash)
Compiling .pioenvs\STM32F1\src\src\HAL\HAL_STM32F1\HAL_timers_STM32F1.cpp.o Marlin\src\HAL\HAL_STM32F1\HAL_sdio_STM32F1.cpp: In function 'bool SDIO_Init()': Marlin\src\HAL\HAL_STM32F1\HAL_sdio_STM32F1.cpp:34:3: error: 'sdio_begin' was not declared in this scope sdio_begin(); ^~~~~~~~~~
Re: Marlin 2.0 and STM32F103C8 February 13, 2019 02:55AM |
Re: Marlin 2.0 and STM32F103C8 November 06, 2024 08:25AM |
Re: Marlin 2.0 and STM32F103C8 November 06, 2024 09:10AM |
Re: Marlin 2.0 and STM32F103C8 November 14, 2024 03:32AM |
Re: Marlin 2.0 and STM32F103C8 November 14, 2024 08:17AM |
Re: Marlin 2.0 and STM32F103C8 November 14, 2024 09:22AM |
diff --git a/Marlin/Configuration.h b/Marlin/Configuration.h index c45c75a39d..43bcf3d846 100644 --- a/Marlin/Configuration.h +++ b/Marlin/Configuration.h @@ -68,7 +68,7 @@ // Choose the name from boards.h that matches your setup #ifndef MOTHERBOARD - #define MOTHERBOARD BOARD_RAMPS_14_EFB + #define MOTHERBOARD BOARD_MORPHEUS #endif // @section serial @@ -81,7 +81,7 @@ * * :[-1, 0, 1, 2, 3, 4, 5, 6, 7, 8, 9] */ -#define SERIAL_PORT 0 +#define SERIAL_PORT 1 /** * Serial Port Baud Rate diff --git a/Marlin/src/pins/pins.h b/Marlin/src/pins/pins.h index e70a70b518..123321dac3 100644 --- a/Marlin/src/pins/pins.h +++ b/Marlin/src/pins/pins.h @@ -608,7 +608,7 @@ #elif MB(GTM32_REV_Also attached, so you can work out what the silly similes are meant to be#include "stm32f1/pins_GTM32_REV_B.h" // STM32F1 env
TM32F103VE env
TM32F103VE_GTM32_maple #elif MB(MORPHEUS) - #include "stm32f1/pins_MORPHEUS.h" // STM32F1 env
TM32F103RE env
TM32F103RE_maple + #include "stm32f1/pins_MORPHEUS.h" // STM32F1 env
TM32F103C8 env
TM32F103CB env
TM32F103RE env
TM32F103RE_maple #elif MB(CHITU3D) #include "stm32f1/pins_CHITU3D.h" // STM32F1 env
TM32F103ZE env
TM32F103RE_maple #elif MB(MKS_ROBIN) diff --git a/ini/stm32f1.ini b/ini/stm32f1.ini index 0978b19476..6f375f7237 100644 --- a/ini/stm32f1.ini +++ b/ini/stm32f1.ini @@ -26,6 +26,24 @@ board_build.variant = MARLIN_F103Rx build_flags = ${stm32_variant.build_flags} -DDEBUG_LEVEL=0 monitor_speed = 115200 + +# +# STM32F103C8 +# +[env
TM32F103C8] +extends = common_stm32 +board = genericSTM32F103C8 +monitor_speed = 115200 + +# +# STM32F103CB +# +[env
TM32F103CB] +extends = common_stm32 +board = genericSTM32F103CB +monitor_speed = 115200 + + # # STM32F103RE # diff --git a/platformio.ini b/platformio.ini index ed1670dc6d..63bed88739 100644 --- a/platformio.ini +++ b/platformio.ini @@ -13,7 +13,7 @@ [platformio] src_dir = Marlin boards_dir = buildroot/share/PlatformIO/boards -default_envs = mega2560 +default_envs = STM32F103CB include_dir = Marlin extra_configs = Marlin/config.ini
Re: Marlin 2.0 and STM32F103C8 November 14, 2024 09:42AM |
Re: Marlin 2.0 and STM32F103C8 November 15, 2024 10:58AM |
xPack OpenOCD, x86_64 Open On-Chip Debugger 0.10.0+dev-00378-ge5be992df (2020-06-26-09:29) Licensed under GNU GPL v2 For bug reports, read [openocd.org] debug_level: 1 hla_swd Error: init mode failed (unable to connect to the target) in procedure 'program' OpenOCD init failed shutdown command invoked
Re: Marlin 2.0 and STM32F103C8 November 16, 2024 12:48AM |
