Hi all,
Application is CNC
Want to put the end stop on the moving part-carriage
The end stop is engaged- motor is stopped
When tool gets out of line, the end stops is released and triggers a motor movement (?) then the end stop is triggered and stops the motor . the end stop is released again, by movement of the tool (carriage)- the movement is caused by the material being machined— does the motor restart the ovement?- provide the path is long enough
Or use the enable pin of the driver?
Thx
Coolerooney
Edited 1 time(s). Last edit at 02/26/2019 01:25PM by Coolerooney.
