millis_t and ELAPSED() doesn't delay March 08, 2019 04:54AM |
FilamentPinStatus=READ(FIL_RUNOUT_PIN)&0xff; const millis_t fil_ms = millis(); millis_t fil_next_ms = 0; // use real time to track filament sensor status (3sec) if((FilamentPinStatus>FilamentPinLastStatus) && (ELAPSED(fil_ms, fil_next_ms))) { fil_next_ms = fil_ms + 3000UL; ... filament runout routine here ...
Re: millis_t and ELAPSED() doesn't delay March 08, 2019 06:15AM |
Admin Registered: 13 years ago Posts: 6,995 |
Re: millis_t and ELAPSED() doesn't delay March 08, 2019 05:40PM |
Dust
your loop is weird...
if((FilamentPinStatus>FilamentPinLastStatus) && (ELAPSED(fil_ms, fil_next_ms))) will always be true the instant FilamentPinStatus>FilamentPinLastStatus as fil_next_ms == 0
FilamentPinStatus=READ(FIL_RUNOUT_PIN)&0xff; if(FilamentPinStatus>FilamentPinLastStatus) { // pin triggered, save current timestamp. const millis_t fil_ms = millis(); static millis_t fil_delay; // since all of this is inside a loop, only set delay time once if (FilamentSetMillis){ // set the delayed timestamp to 3000ms later fil_delay = fil_ms + 3000UL; // this doesn't need to run until the filament is recovered again FilamentSetMillis=false; } // have three seconds passed? if ((FilamentTestStatus>FilamentTestLastStatus) && (ELAPSED(fil_ms, fil_delay))) { ... filament runout routine ... ... set FilamentSetMillis=true as soon as sensor is low again, so the value can get set once on the next pin trigger ...
