End stop-if you put your finger on.....
March 15, 2019 06:59AM
Hi all
If you have a move on Y of say, 400 and you put your finger on the max end stop, the movement stops-ok
If you then remove your finger from the end stop, does it then continue with the movement?
If not, how can I configure Marlin that it does?
Thx
Coolerooney
Re: End stop-if you put your finger on.....
March 15, 2019 09:00AM
It stops...
when the endstop is triggered this tells the controller your at the end of movement. There is no more, you have reached the end of the universe for that axis.
Wanting it move move further does not make sense. That is not an end stop that is something else
March 19, 2019 02:16PM
Thx Dust,
For indulging my Noobness
If both (min and max) end stops are triggered, and the move is to max, when the max end stop is released, then it will move to max?
The last one
Thx
C
March 19, 2019 05:31PM
No
The firmware looks at the endstop in the direction you are trying to move
ie if your trying to move X right, it only looks at the right endstop
March 31, 2019 06:23AM
Hi all,
The enable and disable commands apply for all end stops——M120/M121
Is there a possibility to specify which end stop?
For use with dual steppers, how can additional end stops be assigned?
Thx!
Best,
Coolerooney
