Fysetc Mini 12864 display on Creality CR10S-Pro - is it possible? April 04, 2019 10:32AM |
Re: Fysetc Mini 12864 display on Creality CR10S-Pro - is it possible? April 04, 2019 10:28PM |
Admin Registered: 13 years ago Posts: 7,002 |
Re: Fysetc Mini 12864 display on Creality CR10S-Pro - is it possible? April 05, 2019 04:21AM |
Re: Fysetc Mini 12864 display on Creality CR10S-Pro - is it possible? April 05, 2019 06:33AM |
Re: Fysetc Mini 12864 display on Creality CR10S-Pro - is it possible? April 05, 2019 08:12AM |
Re: Fysetc Mini 12864 display on Creality CR10S-Pro - is it possible? April 05, 2019 09:59AM |
Re: Fysetc Mini 12864 display on Creality CR10S-Pro - is it possible? April 05, 2019 10:14AM |
Re: Fysetc Mini 12864 display on Creality CR10S-Pro - is it possible? May 01, 2019 10:27PM |
Re: Fysetc Mini 12864 display on Creality CR10S-Pro - is it possible? May 01, 2019 11:02PM |
Re: Fysetc Mini 12864 display on Creality CR10S-Pro - is it possible? May 01, 2019 11:31PM |
// Support for Adafruit Neopixel LED driver #define NEOPIXEL_LED #if ENABLED(NEOPIXEL_LED) #define NEOPIXEL_TYPE NEO_RGB // NEO_GRBW / NEO_GRB - four/three channel driver type (defined in Adafruit_NeoPixel.h) #define NEOPIXEL_PIN 25 // LED driving pin on motherboard 4 => D4 (EXP2-5 on Printrboard) / 30 => PC7 (EXP3-13 on Rumba) #define NEOPIXEL_PIXELS 3 // Number of LEDs in the strip #define NEOPIXEL_IS_SEQUENTIAL // Sequential display for temperature change - LED by LED. Disable to change all LEDs at once. #define NEOPIXEL_BRIGHTNESS 127 // Initial brightness (0-255) #define NEOPIXEL_STARTUP_TEST // Cycle through colors at startup #endif
Re: Fysetc Mini 12864 display on Creality CR10S-Pro - is it possible? May 02, 2019 12:57AM |
Re: Fysetc Mini 12864 display on Creality CR10S-Pro - is it possible? May 02, 2019 06:39AM |
Re: Fysetc Mini 12864 display on Creality CR10S-Pro - is it possible? May 20, 2019 12:24PM |
Re: Fysetc Mini 12864 display on Creality CR10S-Pro - is it possible? May 20, 2019 04:57PM |
#if EITHER(FYSETC_MINI_12864_1_2, FYSETC_MINI_12864_2_0) #ifndef RGB_LED_R_PIN #define RGB_LED_R_PIN 41 #endif #ifndef RGB_LED_G_PIN #define RGB_LED_G_PIN 38 #endif #ifndef RGB_LED_B_PIN #define RGB_LED_B_PIN 40 #endif #elif ENABLED(FYSETC_MINI_12864_2_1) #define NEOPIXEL_PIN 25 #endif
#if EITHER(FYSETC_MINI_12864_1_2, FYSETC_MINI_12864_2_0) #ifndef RGB_LED_R_PIN #define RGB_LED_R_PIN 41 #endif #ifndef RGB_LED_G_PIN #define RGB_LED_G_PIN 38 #endif #ifndef RGB_LED_B_PIN #define RGB_LED_B_PIN 40 #endif #elif ENABLED(FYSETC_MINI_12864_2_1) #define NEOPIXEL_PIN 38 #endif
Re: Fysetc Mini 12864 display on Creality CR10S-Pro - is it possible? May 21, 2019 01:03PM |
Re: Fysetc Mini 12864 display on Creality CR10S-Pro - is it possible? June 12, 2019 04:44AM |
