extruder as 4th axis
Posted by scancool
April 16, 2019 10:20PM
has anyone used one of the secondary extruder as a 4th axis?
if no one has done it, the marlin code is pretty big which files I should be looking into to make this modifications?
I will like to add endstop to one of the extruder to make it a 4th axis
Re: extruder as 4th axis
April 19, 2019 08:18AM
Why would you want a 4th axis? That would over-constrain the system
April 19, 2019 08:49AM
Genesys
You seem confused. A 4th axis is not the same as say 4 mounting points on heated bed....
April 19, 2019 09:53AM
No I’m not confused - if you move in 3 dimensional space with 4 axis, your system is overconstrained and may jam
April 19, 2019 10:57AM
4th axis is normally rotation, eg the bed may rotate around Y, so you can print on the side of things..
On 3d printers It can also be a Dual independent X axis, or real physical bed leveling with multiple Z axis....
not over constrained at all..
Edited 2 time(s). Last edit at 04/19/2019 11:18AM by Dust.
April 21, 2019 06:09PM
I'm working on a robotic arm, I want to use this firmware to control it.
Genesys regarding 4th axis 3d printer this is what Dust is referring to
[youtu.be]
