Need help with G29 command
Posted by MikeCL
April 24, 2019 01:37PM
I have a auto level probe but when I do a G29 command it sends my nozzle off the build area and not in the center where I would rather it find the first home for the Z.. I'm not sure if the bed size in Marlin is not right (Anet A8 with ramps 1.4) but I can't seem to get this one.
Re: Need help with G29 command
April 25, 2019 10:34AM
Anyone know?
April 25, 2019 06:13PM
Have you enabled Z_SAFE_HOMING in Configuration.h?
April 26, 2019 07:24AM
I feel like much more information would be useful.
As @MMcLure mentioned, safe homing could cause this, but the default for safe homing is actually center... (bed size/2 in both directions)
- Firmware version (And some context. Are you flashing your own firmware, what version, etc?)
- Ideally, upload your configuration.h
April 26, 2019 02:27PM
For something like an A8 you should define your bed with something like this:
#define X_MIN_POS -33
#define Y_MIN_POS -6
#define X_BED_SIZE 220
#define Y_BED_SIZE 220
leave pretty much everything else that refers to the bed alone. You'll probably have to fine-tune X_MIN_POS and Y_MIN_POS a bit, but those numbers should get you close.
