I have a printer with its home position off the bed....most slicers allow you to compensate for that, but apparently Cura does not....so I am told to have start code which repositions the head and then issue G92 to set a new soft origin....
however, does this skew the bed leveling map or will Marlin compensate that map for a new origin after a G92 command?if it skews the map, then can I issue the resposition and G92 and redo the leveling to make it correspond?
Edited 1 time(s). Last edit at 04/26/2019 11:14AM by hwurzburg.
