Hi There,
My old setup i.e. Arduino Mega + Ramps 1.4 + Inductive sensor SN04-N + 24V + Marlin_2.0_bugfix was running fine. No problem printing. It is a hypercube evolution CoreYX printer
I really have a hard time to get my new setup running i.e. Re-Arm 32-bit + Ramps 1.4 + SN04-N + 24V + Marlin _2.0_bugfix. I have upgraded to the 32-bit board and basically just replaced my Arduino with the Re-Arm board. I was lucky and my optical end stops worked with the 3.3V supply. My SN04-N Inductive sensor was putting out 5V when not triggered and 0V when triggered. The digital pins on the Re-Arm is 5V tolerant and this should have worked as is.
Everything else works except that the SN04-N does not trigger the M119 Command.
I then thought I will setup the divider to have a 3,3V rail to trigger the endstop pin i.e. Z_Minimum inverted no pullups or pulldowns, still no triggering.
I then took the sn04 off and enabled pullup resistor on z_min and when I Ground the pin it triggers M119. So the port is not blown.
I am including my config file so that you can see my configuration.
Configuration.h
What am I missing here?
