CURA 3.6 and Marlin 1.1.9 starts print 5mm above the bed May 15, 2019 11:22AM |
Re: CURA 3.6 and Marlin 1.1.9 starts print 5mm above the bed May 15, 2019 06:11PM |
Re: CURA 3.6 and Marlin 1.1.9 starts print 5mm above the bed May 15, 2019 06:14PM |
Re: CURA 3.6 and Marlin 1.1.9 starts print 5mm above the bed May 16, 2019 12:09PM |
I had my first unexplained 1.1.9 failure (after correcting the configuration.h setting), a thermal runaway shutdown.Quote
dlc60
I found the problem. I left USE_ZMIN_PLUG defined. For some reason that added an offset to the first layer.
Hmm. I'll look into the 1.1.9BF. I have not used 1.1.9 enough to see the bugs.
What does the BF release fix? I didn't see any release notes in github.
thanks,
DLC
Re: CURA 3.6 and Marlin 1.1.9 starts print 5mm above the bed May 16, 2019 07:56PM |
Re: CURA 3.6 and Marlin 1.1.9 starts print 5mm above the bed May 17, 2019 01:24PM |
Roberts_Clif
I had used Marlin 1.1.9BF for quite a long time an never had any problems.
I upgraded to Marlin 2.0.0 several months ago, have never had any problems with this firmware on my Prusa i3 compatible 3D Printer.
This is an ABS print and assembly I just finished for the MPCNC.
XY_C_Burly20
[drive.google.com]
[attachment 111371 MiddleAssembly.jpg]
Re: CURA 3.6 and Marlin 1.1.9 starts print 5mm above the bed May 18, 2019 02:56AM |
Admin Registered: 11 years ago Posts: 3,096 |
Roberts_Clif
XY_C_Burly20
[drive.google.com]
Re: CURA 3.6 and Marlin 1.1.9 starts print 5mm above the bed May 18, 2019 09:35AM |
