Using Z_DUAL_ENDSTOPS for build plate leveling on Z_MAX with probing on Z_MIN May 29, 2019 04:47PM |
Re: Using Z_DUAL_ENDSTOPS for build plate leveling on Z_MAX with probing on Z_MIN May 30, 2019 08:34AM |
Admin Registered: 11 years ago Posts: 3,096 |
Re: Using Z_DUAL_ENDSTOPS for build plate leveling on Z_MAX with probing on Z_MIN May 30, 2019 08:48AM |
Maybe my choice of words wasn't the best. It's not problem while printing. But when I remove print surface (flexible) or poke around printer, then I sometimes accidentally move one lead screw. When that happens I need to manually level it again. I would like to have a way to do it automatically before every print.Quote
Ohmarinus
I feel like this is working around the problem. Sorry for not providing an answer, but wouldn't it be a better idea to fix the steppers going out of sync?
What could be the cause of that? Binding? An axis leadscrew slipping in relation to the stepper shaft?
Re: Using Z_DUAL_ENDSTOPS for build plate leveling on Z_MAX with probing on Z_MIN June 01, 2019 10:16AM |
Re: Using Z_DUAL_ENDSTOPS for build plate leveling on Z_MAX with probing on Z_MIN June 02, 2019 06:41PM |
Re: Using Z_DUAL_ENDSTOPS for build plate leveling on Z_MAX with probing on Z_MIN June 03, 2019 09:31AM |
Re: Using Z_DUAL_ENDSTOPS for build plate leveling on Z_MAX with probing on Z_MIN June 03, 2019 10:59AM |
Re: Using Z_DUAL_ENDSTOPS for build plate leveling on Z_MAX with probing on Z_MIN June 03, 2019 01:59PM |
Re: Using Z_DUAL_ENDSTOPS for build plate leveling on Z_MAX with probing on Z_MIN June 03, 2019 05:42PM |
Ohmarinus
Just a thought, but do you think it would be an idea to add a belt around both axes or a sting that is looped around then a couple of times so that the axes also keep each other physically in sync?
Re: Using Z_DUAL_ENDSTOPS for build plate leveling on Z_MAX with probing on Z_MIN June 04, 2019 09:40AM |
MKSA
Ohmarinus
It is the way to go. One motor plus closed loop belt. Synchronous belts have been "invented" decades ago to address this.
Re: Using Z_DUAL_ENDSTOPS for build plate leveling on Z_MAX with probing on Z_MIN June 04, 2019 09:56AM |
Currently I'm using similar approach, but I would like to have it automated in the future.Quote
MMcLure
I use a low-tech solution for this problem - I have a couple of 3D printed jigs that fit around the Z axis rods. I put those in place, turn the lead screws by hand until the axis hits the jig on each side, pull the jigs out, and presto - the axis is level and ready to go.
Re: Using Z_DUAL_ENDSTOPS for build plate leveling on Z_MAX with probing on Z_MIN June 04, 2019 10:00AM |
