Manual Bed Leveling Question.
Posted by yoch
July 02, 2019 09:48AM
Is there a setting to lower the initial head height when manually bed leveling?
If the initial value is 5 mm and the step is 0.05 mm, the hand that turns the encoder gets tired.
Re: Manual Bed Leveling Question.
October 01, 2019 02:50AM
Enabled 4 corner leveling in configuration.h
October 01, 2019 09:37AM
When I started out I used the LCD to set Z-Offset in marlin to adjust the nozzle height.
You can also use.
M851 - XYZ Probe Offset to set the Z-Offset.
Today I use babysteps to nudge the nozzle into place while 3D Printing a skirt around the model using the LCD.
#define BABYSTEPPING
I have also added a spring loaded sensor mount to adjust the Z-Axis sensor/endstop into the correct position without using above configurations.
Edited 1 time(s). Last edit at 10/01/2019 09:43AM by Roberts_Clif.
