Hi everyone
I have an issue (or possibly a discovered bug) where I enable EEPROM_SETTINGS in Configuration.h and I get TMC CONNECTION ERROR on the LCD
M122 shows:
X Y E
Enabled false false false
Set current 0 0 0
RMS current 55 55 55
MAX current 78 78 78
Run current 0/31 0/31 0/31
Hold current 0/31 0/31 0/31
CS actual 0/31 0/31 0/31
PWM scale 0 0 0
vsense 0=.325 0=.325 0=.325
stealthChop false false false
msteps 256 256 256
tstep 0 0 0
pwm
threshold
[mm/s]
OT prewarn false false false
OT prewarn has
been triggered false false false
off time 0 0 0
blank time 16 16 16
hysteresis
-end -3 -3 -3
-start 1 1 1
Stallguard thrs 0 0 0
DRVSTATUS X Y E
stallguard
sg_result 0 0 0
fsactive
stst
olb
ola
s2gb
s2ga
otpw
ot
Driver registers:
X 0x00:00:00:00 Bad response!
Y 0x00:00:00:00 Bad response!
E 0x00:00:00:00 Bad response!
Testing X connection... Error: All LOW
Testing Y connection... Error: All LOW
Testing E connection... Error: All LOW
( Z is not running a TMC driver)
With EEPROM_SETTINGS disabled I have no problems at all and can run the drivers in spreadCycle, stealthChop, and Stallguard works but as soon as I enable EEPROM_SETTINGS nothing works.
I have tried running an M502 to reset EEPROM and then an M122 which results in all "OK" from the TMC's but it still refuses to do anything. I have then tried an M500 after that to save what the M502 did and then a reboot and its back to the "ALL LOW" error.
My setup is an SKR 1.3 running the latest Marlin bugfix-2.0.x release from GitHub as of 2 days ago and 3 TMC 2130's on X, Y, and E0 configured with SW SPI because the SKR has it built in. I have an A4889 on the Z axis. Also connected is a "RepRap Discount Full Graphic Smart Controller" but removing this seems to have no impact. I have attached the zip with my configuration files.
Configuration.zip Thanks in advance!
