M600 or filament change feature activates at the beginning
Posted by punisher80
July 10, 2019 11:14AM
Hello.
Recently I installed filament runout sensor.
I have uncommented advanced_pause_feature and nozzle_park_feature to make it work and then I booted it into my ender-3.
Expected behavior: printer start to print without any stops
Actual behavior: printer activates filament change feature after auto home
Steps to reproduce:
Start print
Wait till print do auto home
Check LCD with filament change command
(If you proceed with filament change feature it will purge the filament and then repeat it again.)
This is my first post here, let me know if something wrong.
open | download - Configuration.h (70 KB)
open | download - Configuration_adv.h (67.3 KB)
Re: M600 or filament change feature activates at the beginning
August 16, 2019 09:45AM
Hi
Did you sent M119 to the printer?
You can see if the sensor is working properly
If the filament sensor appears open, you need to change the FIL_RUNOUT_INVERTING
I hope this was helpful
Baliza
August 16, 2019 08:49PM
baliza
Hi
Baliza
Agreed;
When my filament run-out sensor was set to the wrong state this looping processing is exactly what is does.
Edited 1 time(s). Last edit at 08/16/2019 08:49PM by Roberts_Clif.
