Marlin 2.0.x delta printer auto bed level issue August 19, 2019 11:27AM |
Re: Marlin 2.0.x delta printer auto bed level issue August 24, 2019 06:04PM |
DocSolo
Hi all,
I'm having an issue trying to calibrare my homebuilt delta printer. I'm using BTT SKR v1.3 with latest Marlin 2.0 firmware. I am including a zip file containing the debug with S247 option and my config files. The way it works at the moment is G28 is partially working, as in: hit the 3 endstops but only does the slow bump on Y and Z axes. Sending the G33 homes the same way, goes down about 60 mm, move toward the Z tower 9 mm, up 5 mm then throws off [ERROR] Errorrobing Failed and stop. It used to work back on 28/07/2019 and 07/08/2019 but I don't take note of the commit ID. I have been building and testing a lot of builds from around those dates without success.
Being a computer tech and geek at large, I try to stay up to date on all software most of the time without issue.
Now, I'm thinking that not every people working on the codebase is using the same code as once in a while it works for me and a lot of time it does not.
Any help would be appreciated. Thanks in advance,
DocSolo
Re: Marlin 2.0.x delta printer auto bed level issue August 25, 2019 07:07AM |
Re: Marlin 2.0.x delta printer auto bed level issue August 25, 2019 07:28AM |
Admin Registered: 13 years ago Posts: 7,002 |
Re: Marlin 2.0.x delta printer auto bed level issue August 25, 2019 09:51PM |
Re: Marlin 2.0.x delta printer auto bed level issue August 26, 2019 07:22AM |
Re: Marlin 2.0.x delta printer auto bed level issue August 27, 2019 06:02PM |
Re: Marlin 2.0.x delta printer auto bed level issue August 28, 2019 05:12PM |
Dust
why are you using mixed stepper drivers on delta towers ??
from your configuration.h
#define X_DRIVER_TYPE TMC2100
#define Y_DRIVER_TYPE TMC2100
#define Z_DRIVER_TYPE A4988
I'm not saying this is an issue, but it does seem an odd choice
Re: Marlin 2.0.x delta printer auto bed level issue September 09, 2019 06:51PM |
