TMC2130 Only Moves 1 step, Sensorless Homing August 28, 2019 10:35PM |
start echo:Marlin bugfix-2.0.x echo: Last Updated: 2019-07-05 | Author: (none, default config) echo:Compiled: Aug 25 2019 echo: Free Memory: 5185 PlannerBufferBytes: 1216 echo:V67 stored settings retrieved (622 bytes; crc 25960) echo: G21 ; Units in mm (mm) echo: Filament settings: Disabled echo: M200 D3.00 echo: M200 D0 echo: Steps per unit: echo: M92 X80.00 Y80.00 Z5120.00 E500.00 echo: Maximum feedrates (units/s): echo: M203 X300.00 Y300.00 Z30.00 E25.00 echo: Maximum Acceleration (units/s2): echo: M201 X3000.00 Y3000.00 Z100.00 E10000.00 echo: Acceleration (units/s2): P R T echo: M204 P3000.00 R3000.00 T3000.00 echo: Advanced: B S T X Y Z E echo: M205 B20000.00 S0.00 T0.00 X10.00 Y10.00 Z0.30 E5.00 echo: Home offset: echo: M206 X0.00 Y0.00 Z0.00 echo: Endstop adjustment: echo: M666 X0.00 Y0.00 echo: PID settings: echo: M301 P22.20 I1.08 D114.00 echo: Stepper driver current: echo: M906 X800 Y800 echo: M906 I1 X800 Y800 echo: StallGuard threshold: echo: M914 X8 Y8 M914 I1 X8 Y8 echo: Driver stepping mode: echo: Testing X connection... OK Testing X2 connection... OK Testing Y connection... OK Testing Y2 connection... OK M122 X X2 Y Y2 Enabled false false false false Set current 800 800 800 800 RMS current 795 795 795 795 MAX current 1121 1121 1121 1121 Run current 25/31 25/31 25/31 25/31 Hold current 12/31 12/31 12/31 12/31 CS actual 12/31 12/31 12/31 12/31 PWM scale 0 0 0 0 vsense 1=.18 1=.18 1=.18 1=.18 stealthChop false false false false msteps 16 16 16 16 tstep max max max max pwm threshold [mm/s] OT prewarn false false false false OT prewarn has been triggered false false false false off time 4 4 4 4 blank time 24 24 24 24 hysteresis -end 2 2 2 2 -start 1 1 1 1 Stallguard thrs 8 8 8 8 DRVSTATUS X X2 Y Y2 stallguard sg_result 0 0 0 0 fsactive stst * * * * olb * * * * ola * * * * s2gb s2ga otpw ot Driver registers: X 0xE0:0C:00:00 X2 0xE0:0C:00:00 Y 0xE0:0C:00:00 Y2 0xE0:0C:00:00 Testing X connection... OK Testing X2 connection... OK Testing Y connection... OK Testing Y2 connection... OK ok G28 echo:busy: processing echo:busy: processing echo:busy: processing echo:busy: processing echo:busy: processing echo:busy: processing echo:busy: processing echo:busy: processing echo:busy: processing echo:busy: processing echo:busy: processing echo:busy: processing echo:busy: processing echo:busy: processing echo:busy: processing echo:busy: processing echo:busy: processing echo:busy: processing echo:busy: processing echo:busy: processing echo:busy: processing echo:busy: processing echo:busy: processing echo:busy: processing echo:busy: processing echo:busy: processing echo:busy: processing echo:busy: processing echo:busy: processing echo:busy: processing echo:busy: processing echo:busy: processing echo:busy: processing echo:busy: processing echo:busy: processing
Re: TMC2130 Only Moves 1 step, Sensorless Homing August 29, 2019 04:15AM |
Admin Registered: 16 years ago Posts: 13,888 |
Re: TMC2130 Only Moves 1 step, Sensorless Homing August 29, 2019 10:55AM |
Re: TMC2130 Only Moves 1 step, Sensorless Homing August 29, 2019 11:38AM |
