Marlin 2.0 BugFix on ReArm controller
Posted by G3DBuilder
September 11, 2019 12:35PM
I Have successfully compiled Marlin 2.0 BugFix to the MicroSD on the ReArm controller using Platform IO ( interestingly not real easy) although I now have a Firmware.cur file and the ReArm board responds to M commands.
My question is;
The documentation states that the configuration.h and configuration_adv.h can be modified without recompiling. Do I Just need to copy both *.h files to the sd memory card and edit it from there. Platform IO only writes Firmware.bin.
I cannot find any documentation that states how the ReArm board handles these files.
Thanks for any input.
Re: Marlin 2.0 BugFix on ReArm controller
September 11, 2019 01:20PM
Don't know what documentation your looking at, but its wrong.
In marlin Configuration.h changes need compiled in. Though a lot can be change with the appropriate gcode later.
Edited 1 time(s). Last edit at 09/12/2019 03:54AM by Dust.
September 11, 2019 02:01PM
So this is what's written on Panucatt's Web Site;
"Easy configuration using a text file on SD card, no need to upload firmware every settings change."
I don't know what text file they are referring to then.
I have sent Panucatt a ticket to ask them the same question.
Thanks,
Edited 1 time(s). Last edit at 09/11/2019 02:13PM by G3DBuilder.
September 11, 2019 02:45PM
OK, Did some more research, The text file that Panucatt is referring to may be for Smoothie Ware only. (never used it)
I bet they "Panucatt" will come back with the same answer.
Anyway good info, it has been an interesting learning experience.
September 12, 2019 01:38AM
That is for smoothiware and the config file is simply called config or config.txt
This has nothing to do with marlin.
