Hello,
I`m printing with clay using the E0 stepper inside the extruder head and an air compressor to feed the extruder with clay.
I want to replace the compressor with another stepper that pushes a plunger, helped with a gearbox, so i need the same movement in both steppers.
I achieve installing the second stepper and moving it with the G-code but picking out first the one that i want to move with T0 and T1, so i can`t move them simultaneously with the same order.
The Firmware I`m using is Marlin 1.1.9, and the board is a Trigorilla (Anycubic Kossel) which is equivalent to the RAMPS 14,
Thanks in advance
