Marlin 2.0 Anycubic Chiron
Posted by elloder
November 01, 2019 04:30AM
Hello everyone,
I wanted to install the TMC 2209 into my Anycubic Chiron, which needs the Marlin 2.0 to run, however, I have not found the Marlin 2.0 for the Chiron anywhere in this zip or on google... do any of you have any ideas if there is a Marlin 2.0 for the Chiron? Also I am a very big beginner in terms of the firmware so I would like to ask the specific differences between Marlin 2.O and the 1.1.
Cheers,
Maty.
Re: Marlin 2.0 Anycubic Chiron
November 01, 2019 04:48AM
"specific differences between Marlin 2.O and the 1.1."
Everything. It is a complete rewrite to support 32 bit processors and the original 8 bit. And an uncountable number of improvements.
Edited 1 time(s). Last edit at 11/01/2019 04:53AM by Dust.
November 01, 2019 05:07AM
Why do you think this printer needs marlin 2.0? when it looks like it comes with a old ramps compatible controller.. (TriGorilla)
Edited 2 time(s). Last edit at 11/01/2019 05:14AM by Dust.
November 01, 2019 05:12AM
Dust
Why do you think this printer needs marlin 2.0? when it looks like it comes with a old ramps compatible controller...
I think it's because of the TMC drivers.
http://www.marinusdebeer.nl/
November 01, 2019 05:25AM
Looks like your correct. no mention of TMC 2209 in 1.1.x branch..
Seems like someone is bringing out a new stepper driver every other week...
November 01, 2019 05:44AM
closest I can find is [www.thingiverse.com]
It is 2.0 but they are using a standard GLCD vs the supplied screen.
or a 1.1.9 version [www.thingiverse.com]
which the config files should be very similar to 2.0 standard. But there is a lot of code changes to support the special screen.
What you want just doesn't exist yet. And you will need to be a coder to implement it.
You can add a feature request to marlin 2.0 on github to implement CHIRON_LCD as found in https://github.com/dkoch83/Marlin-1.1.9_Anycubic_Chiron
This will be received much better than your first attempt (though boelle will still try and bite your head off.... It is what he does.)
Edited 4 time(s). Last edit at 11/01/2019 06:14AM by Dust.
February 23, 2020 09:58AM
Hello.
I am realy interested. I want to fix bulge corners issue in my Chiron and I think that the Linear Advance factor it's the best way.
Can you explain me how to update my Chiron with this version of Marlin 1.1.9 in Arduino IDE. Which settings should I use??
Thanks in advance.
