Seem to be worst, here is result:
Verbose mode can be enabled via `-v, --verbose` option
CONFIGURATION: [
docs.platformio.org]
PLATFORM: NXP Arduino LPC176x 0.0.2 > NXP LPC1768
HARDWARE: LPC1768 100MHz, 31.80KB RAM, 464KB Flash
DEBUG: Current (cmsis-dap) On-board (cmsis-dap) External (blackmagic, jlink)
PACKAGES: framework-arduino-lpc176x 0.1.3, toolchain-gccarmnoneeabi 1.80201.190214 (8.2.1)
Converting Marlin.ino
LDF: Library Dependency Finder -> [
bit.ly]
LDF Modes: Finder ~ off, Compatibility ~ strict
Found 6 compatible libraries
Scanning dependencies...
Dependency Graph
|-- 1.0.0
|-- 1.0.0
|-- 0.4
|-- 0.5.2
|-- 1.2.4
Unable to find destination disk (Autodetect Error)
Please select it in platformio.ini using the upload_port keyword (https://docs.platformio.org/en/latest/projectconf/section_env_upload.html) or copy the firmware (.pio/build/LPC1768/firmware.bin) manually to the appropriate disk
Linking .pio\build\LPC1768\firmware.elf
c:/users/systadmin/.platformio/packages/toolchain-gccarmnoneeabi/bin/../lib/gcc/arm-none-eabi/8.2.1/../../../../arm-none-eabi/bin/ld.exe: .pio/build/LPC1768/src/src/gcode/sdcard/M20.cpp.o: in function `GcodeSuite::M20()':
c:\3dprinter\BIGTREETECH-SKR-V1.3-master\firmware\Marlin-bugfix-2.0.x/Marlin\src\gcode\sdcard/M20.cpp:33: multiple definition of `GcodeSuite::M20()'; .pio/build/LPC1768/src/src/gcode/sdcard/M20-M30_M32-M34_M524_M928.cpp.o:c:\3dprinter\BIGTREETECH-SKR-V1.3-master\firmware\Marlin-bugfix-2.0.x/Marlin\src\gcode\sdcard\../parser.h:133: first defined here
c:/users/systadmin/.platformio/packages/toolchain-gccarmnoneeabi/bin/../lib/gcc/arm-none-eabi/8.2.1/../../../../arm-none-eabi/bin/ld.exe: .pio/build/LPC1768/src/src/gcode/sdcard/M21_M22.cpp.o: in function `GcodeSuite::M21()':
c:\3dprinter\BIGTREETECH-SKR-V1.3-master\firmware\Marlin-bugfix-2.0.x/Marlin\src\gcode\sdcard/M21_M22.cpp:33: multiple definition of `GcodeSuite::M21()'; .pio/build/LPC1768/src/src/gcode/sdcard/M20-M30_M32-M34_M524_M928.cpp.o:c:\3dprinter\BIGTREETECH-SKR-V1.3-master\firmware\Marlin-bugfix-2.0.x/Marlin\src\gcode\sdcard\../parser.h:102: first defined here
c:/users/systadmin/.platformio/packages/toolchain-gccarmnoneeabi/bin/../lib/gcc/arm-none-eabi/8.2.1/../../../../arm-none-eabi/bin/ld.exe: .pio/build/LPC1768/src/src/gcode/sdcard/M21_M22.cpp.o: in function `GcodeSuite::M22()':
c:\3dprinter\BIGTREETECH-SKR-V1.3-master\firmware\Marlin-bugfix-2.0.x/Marlin\src\gcode\sdcard/M21_M22.cpp:38: multiple definition of `GcodeSuite::M22()'; .pio/build/LPC1768/src/src/gcode/sdcard/M20-M30_M32-M34_M524_M928.cpp.o:c:\3dprinter\BIGTREETECH-SKR-V1.3-master\firmware\Marlin-bugfix-2.0.x/Marlin\src\gcode\sdcard\../parser.h:102: first defined here
c:/users/systadmin/.platformio/packages/toolchain-gccarmnoneeabi/bin/../lib/gcc/arm-none-eabi/8.2.1/../../../../arm-none-eabi/bin/ld.exe: .pio/build/LPC1768/src/src/gcode/sdcard/M23.cpp.o: in function `GcodeSuite::M23()':
c:\3dprinter\BIGTREETECH-SKR-V1.3-master\firmware\Marlin-bugfix-2.0.x/Marlin\src\gcode\sdcard/M23.cpp:38: multiple definition of `GcodeSuite::M23()'; .pio/build/LPC1768/src/src/gcode/sdcard/M20-M30_M32-M34_M524_M928.cpp.o:c:\3dprinter\BIGTREETECH-SKR-V1.3-master\firmware\Marlin-bugfix-2.0.x/Marlin\src\gcode\sdcard\../parser.h:102: first defined here
c:/users/systadmin/.platformio/packages/toolchain-gccarmnoneeabi/bin/../lib/gcc/arm-none-eabi/8.2.1/../../../../arm-none-eabi/bin/ld.exe: .pio/build/LPC1768/src/src/gcode/sdcard/M24_M25.cpp.o: in function `GcodeSuite::M24()':
c:\3dprinter\BIGTREETECH-SKR-V1.3-master\firmware\Marlin-bugfix-2.0.x/Marlin\src\gcode\sdcard/M24_M25.cpp:44: multiple definition of `GcodeSuite::M24()'; .pio/build/LPC1768/src/src/gcode/sdcard/M20-M30_M32-M34_M524_M928.cpp.o:c:\3dprinter\BIGTREETECH-SKR-V1.3-master\firmware\Marlin-bugfix-2.0.x/Marlin\src\gcode\sdcard\../parser.h:102: first defined here
c:/users/systadmin/.platformio/packages/toolchain-gccarmnoneeabi/bin/../lib/gcc/arm-none-eabi/8.2.1/../../../../arm-none-eabi/bin/ld.exe: .pio/build/LPC1768/src/src/gcode/sdcard/M24_M25.cpp.o: in function `GcodeSuite::M25()':
c:\3dprinter\BIGTREETECH-SKR-V1.3-master\firmware\Marlin-bugfix-2.0.x/Marlin\src\gcode\sdcard/M24_M25.cpp:82: multiple definition of `GcodeSuite::M25()'; .pio/build/LPC1768/src/src/gcode/sdcard/M20-M30_M32-M34_M524_M928.cpp.o:c:\3dprinter\BIGTREETECH-SKR-V1.3-master\firmware\Marlin-bugfix-2.0.x/Marlin\src\gcode\sdcard/M20-M30_M32-M34_M524_M928.cpp:121: first defined here
c:/users/systadmin/.platformio/packages/toolchain-gccarmnoneeabi/bin/../lib/gcc/arm-none-eabi/8.2.1/../../../../arm-none-eabi/bin/ld.exe: .pio/build/LPC1768/src/src/gcode/sdcard/M26.cpp.o: in function `GcodeSuite::M26()':
c:\3dprinter\BIGTREETECH-SKR-V1.3-master\firmware\Marlin-bugfix-2.0.x/Marlin\src\gcode\sdcard/M26.cpp:33: multiple definition of `GcodeSuite::M26()'; .pio/build/LPC1768/src/src/gcode/sdcard/M20-M30_M32-M34_M524_M928.cpp.o:c:\3dprinter\BIGTREETECH-SKR-V1.3-master\firmware\Marlin-bugfix-2.0.x/Marlin\src\gcode\sdcard/M20-M30_M32-M34_M524_M928.cpp:148: first defined here
c:/users/systadmin/.platformio/packages/toolchain-gccarmnoneeabi/bin/../lib/gcc/arm-none-eabi/8.2.1/../../../../arm-none-eabi/bin/ld.exe: .pio/build/LPC1768/src/src/gcode/sdcard/M27.cpp.o: in function `GcodeSuite::M27()':
c:\3dprinter\BIGTREETECH-SKR-V1.3-master\firmware\Marlin-bugfix-2.0.x/Marlin\src\gcode\sdcard/M27.cpp:35: multiple definition of `GcodeSuite::M27()'; .pio/build/LPC1768/src/src/gcode/sdcard/M20-M30_M32-M34_M524_M928.cpp.o:c:\3dprinter\BIGTREETECH-SKR-V1.3-master\firmware\Marlin-bugfix-2.0.x/Marlin\src\gcode\sdcard/M20-M30_M32-M34_M524_M928.cpp:158: first defined here
c:/users/systadmin/.platformio/packages/toolchain-gccarmnoneeabi/bin/../lib/gcc/arm-none-eabi/8.2.1/../../../../arm-none-eabi/bin/ld.exe: .pio/build/LPC1768/src/src/gcode/sdcard/M28_M29.cpp.o: in function `GcodeSuite::M28()':
c:\3dprinter\BIGTREETECH-SKR-V1.3-master\firmware\Marlin-bugfix-2.0.x/Marlin\src\gcode\sdcard/M28_M29.cpp:61: multiple definition of `GcodeSuite::M28()'; .pio/build/LPC1768/src/src/gcode/sdcard/M20-M30_M32-M34_M524_M928.cpp.o:c:\3dprinter\BIGTREETECH-SKR-V1.3-master\firmware\Marlin-bugfix-2.0.x/Marlin\src\gcode\sdcard/M20-M30_M32-M34_M524_M928.cpp:203: first defined here
c:/users/systadmin/.platformio/packages/toolchain-gccarmnoneeabi/bin/../lib/gcc/arm-none-eabi/8.2.1/../../../../arm-none-eabi/bin/ld.exe: .pio/build/LPC1768/src/src/gcode/sdcard/M28_M29.cpp.o: in function `GcodeSuite::M29()':
c:\3dprinter\BIGTREETECH-SKR-V1.3-master\firmware\Marlin-bugfix-2.0.x/Marlin\src\gcode\sdcard/M28_M29.cpp:71: multiple definition of `GcodeSuite::M29()'; .pio/build/LPC1768/src/src/gcode/sdcard/M20-M30_M32-M34_M524_M928.cpp.o:c:\3dprinter\BIGTREETECH-SKR-V1.3-master\firmware\Marlin-bugfix-2.0.x/Marlin\src\gcode\sdcard/M20-M30_M32-M34_M524_M928.cpp:213: first defined here
c:/users/systadmin/.platformio/packages/toolchain-gccarmnoneeabi/bin/../lib/gcc/arm-none-eabi/8.2.1/../../../../arm-none-eabi/bin/ld.exe: .pio/build/LPC1768/src/src/gcode/sdcard/M30.cpp.o: in function `GcodeSuite::M30()':
c:\3dprinter\BIGTREETECH-SKR-V1.3-master\firmware\Marlin-bugfix-2.0.x/Marlin\src\gcode\sdcard/M30.cpp:33: multiple definition of `GcodeSuite::M30()'; .pio/build/LPC1768/src/src/gcode/sdcard/M20-M30_M32-M34_M524_M928.cpp.o:c:\3dprinter\BIGTREETECH-SKR-V1.3-master\firmware\Marlin-bugfix-2.0.x/Marlin\src\gcode\sdcard/M20-M30_M32-M34_M524_M928.cpp:219: first defined here
c:/users/systadmin/.platformio/packages/toolchain-gccarmnoneeabi/bin/../lib/gcc/arm-none-eabi/8.2.1/../../../../arm-none-eabi/bin/ld.exe: .pio/build/LPC1768/src/src/gcode/sdcard/M32.cpp.o: in function `GCodeParser::has_value()':
c:\3dprinter\BIGTREETECH-SKR-V1.3-master\firmware\Marlin-bugfix-2.0.x/Marlin\src\gcode\sdcard/M32.cpp:42: multiple definition of `GcodeSuite::M32()'; .pio/build/LPC1768/src/src/gcode/sdcard/M20-M30_M32-M34_M524_M928.cpp.o:c:\3dprinter\BIGTREETECH-SKR-V1.3-master\firmware\Marlin-bugfix-2.0.x/Marlin\src\gcode\sdcard/M20-M30_M32-M34_M524_M928.cpp:236: first defined here
c:/users/systadmin/.platformio/packages/toolchain-gccarmnoneeabi/bin/../lib/gcc/arm-none-eabi/8.2.1/../../../../arm-none-eabi/bin/ld.exe: .pio/build/LPC1768/src/src/gcode/sdcard/M524.cpp.o: in function `GcodeSuite::M524()':
c:\3dprinter\BIGTREETECH-SKR-V1.3-master\firmware\Marlin-bugfix-2.0.x/Marlin\src\gcode\sdcard/M524.cpp:35: multiple definition of `GcodeSuite::M524()'; .pio/build/LPC1768/src/src/gcode/sdcard/M20-M30_M32-M34_M524_M928.cpp.o:c:\3dprinter\BIGTREETECH-SKR-V1.3-master\firmware\Marlin-bugfix-2.0.x/Marlin\src\gcode\sdcard/M20-M30_M32-M34_M524_M928.cpp:293: first defined here
c:/users/systadmin/.platformio/packages/toolchain-gccarmnoneeabi/bin/../lib/gcc/arm-none-eabi/8.2.1/../../../../arm-none-eabi/bin/ld.exe: .pio/build/LPC1768/src/src/gcode/sdcard/M928.cpp.o: in function `GcodeSuite::M928()':
c:\3dprinter\BIGTREETECH-SKR-V1.3-master\firmware\Marlin-bugfix-2.0.x/Marlin\src\gcode\sdcard/M928.cpp:35: multiple definition of `GcodeSuite::M928()'; .pio/build/LPC1768/src/src/gcode/sdcard/M20-M30_M32-M34_M524_M928.cpp.o:c:\3dprinter\BIGTREETECH-SKR-V1.3-master\firmware\Marlin-bugfix-2.0.x/Marlin\src\gcode\sdcard/M20-M30_M32-M34_M524_M928.cpp:300: first defined here
c:/users/systadmin/.platformio/packages/toolchain-gccarmnoneeabi/bin/../lib/gcc/arm-none-eabi/8.2.1/../../../../arm-none-eabi/bin/ld.exe: .pio/build/LPC1768/src/src/lcd/menu/menu_sdcard.cpp.o: in function `lcd_sd_updir()':
c:\3dprinter\BIGTREETECH-SKR-V1.3-master\firmware\Marlin-bugfix-2.0.x/Marlin\src\lcd\menu/menu_sdcard.cpp:41: multiple definition of `lcd_sd_updir()'; .pio/build/LPC1768/src/src/lcd/menu/menu_media.cpp.o:c:\3dprinter\BIGTREETECH-SKR-V1.3-master\firmware\Marlin-bugfix-2.0.x/Marlin\src\lcd\menu/menu_media.cpp:41: first defined here
collect2.exe: error: ld returned 1 exit status
*** [.pio\build\LPC1768\firmware.elf] Error 1
============================================================================ [ERROR] Took 10.04 seconds ============================================================================
==================================================================================== [SUMMARY] ====================================================================================
Environment megaatmega2560 [IGNORED]
Environment megaatmega1280 [IGNORED]
Environment at90usb1286_cdc [IGNORED]
Environment at90usb1286_dfu [IGNORED]
Environment DUE [IGNORED]
Environment DUE_USB [IGNORED]
Environment DUE_debug [IGNORED]
Environment LPC1768 [FAILED]
Environment LPC1769 [IGNORED]
Environment melzi [IGNORED]
Environment melzi_optiboot [IGNORED]
Environment rambo [IGNORED]
Environment sanguino_atmega644p [IGNORED]
Environment sanguino_atmega1284p [IGNORED]
Environment STM32F1 [IGNORED]
Environment fysetc_STM32F1 [IGNORED]
Environment BIGTREE_SKR_MINI [IGNORED]
Environment STM32F4 [IGNORED]
Environment STM32F7 [IGNORED]
Environment ARMED [IGNORED]
Environment alfawise_U20 [IGNORED]
Environment mks_robin [IGNORED]
Environment mks_robin_lite [IGNORED]
Environment mks_robin_mini [IGNORED]
Environment mks_robin_nano [IGNORED]
Environment jgaurora_a5s_a1 [IGNORED]
Environment black_stm32f407ve [IGNORED]
Environment BIGTREE_SKR_PRO [IGNORED]
Environment BIGTREE_BTT002 [IGNORED]
Environment teensy31 [IGNORED]
Environment teensy35 [IGNORED]
Environment malyanm200 [IGNORED]
Environment esp32 [IGNORED]
Environment fysetc_f6_13 [IGNORED]
Environment linux_native [IGNORED]
Environment adafruit_grandcentral_m4 [IGNORED]
====================================================================== 1 failed, 0 succeeded in 10.15 seconds ======================================================================
The terminal process terminated with exit code: 1
