Re: MKS SGen L V1.0 March 18, 2020 09:23AM |
Re: MKS SGen L V1.0 March 18, 2020 10:18AM |
Re: MKS SGen L V1.0 March 18, 2020 11:04AM |
I removed the jumpers under the drivers, and testing via pronterface says communication to drivers is ok.|
Re: MKS SGen L V1.0 March 18, 2020 11:30AM |
Re: MKS SGen L V1.0 March 18, 2020 03:05PM |
Re: MKS SGen L V1.0 March 18, 2020 03:34PM |
Re: MKS SGen L V1.0 June 23, 2020 08:17PM |
jaded
commo81
Wow, thanks. At least I can see pin assignments now, unfortunately, I had tried the E0 line for enabling heat fan to come on above 50 degrees and it just didn't work for some reason. I have a MKS GEN L board coming with the ATMEGA 2560 onboard and I think I am just going to use that and if it works, I'll be sending the MKS SGEN_L board back because this is just a headache for me with the issues I am having, mostly my EZABL not working on Z_MIN or Z_MAX. Banging my head on my desk over here lol. I really don't care to be up until 3am again tonight.
On the mks base boards I have flashed I had to specify the pin for the fan that I was using for the extruder cooling fan.
On the mks base that would have been d10 or d7 depending on which I was using.
Since I haven't dug into flashing the sgen yet I am not sure what pin it would be.
I can tell you that the above 50 degree auto fan turn on and off works. It's just a matter of finding the right pin.
Re: MKS SGen L V1.0 October 26, 2020 04:58AM |
