Marlin set up for cold runs
Posted by Coolerooney
February 22, 2020 04:47PM
Hi all,
Using marlin/ramps for a non 3d printing application
Keep getting problems with the temp settings- KILL messages
Tried the cold extrude sttettings, standard fixed thermocouple resistor settings etc
In some standard cnc setiings , you only keep the min end stops, i need them all, including the end filament sensors (for other uses)
Suggestions- or better - a ready ino?
Thx
C
Edited 1 time(s). Last edit at 02/22/2020 04:48PM by Coolerooney.
Re: Marlin set up for cold runs
February 23, 2020 12:40AM
If you don't send the printer gcode to heat up, it doesn't....
You cant really use E axis for anything other than an extruder... it is a) tied to temperature (which can be over ridden) , b) tied for feed rates of X and Y moves, which cannot be changed
VDX
February 23, 2020 04:03AM
... I'm using Marlin for pastedispensing, laserengraving/cutting, CNC-milling -- and (industrial) ultrsonic cleaners with up to 5 vats with dryer and up to 3m horizontal travel range.
Most of this applications can run with the standard setup, when avoiding temperature setting/measuring or changing the mintemp values to 0 - for dispensing and laserengraving I've set the "E-steps_per_mm" to 1 and modifying the E-value in the G-code (modified Pronterface or external program modules) to create an exact pulse-ratio for the application.
For outputting 100 pulses per mm for a line, I'm calcualting the line length in mm and the resulting E-value is then the line length x 100 cool smiley
Viktor
February 23, 2020 04:21AM
Hi Guys,
Thanks for the feedback
Dust: there will be no E motor/driver only want to use the end filament switch to call a modified M600 routine- basically homing all axis
VDA: yes thats the trick, but cant seem to get it done- the setting that make the moves completely temp independent- elude me
Thx in advance.....
Best
C
Edited 1 time(s). Last edit at 02/23/2020 04:22AM by Coolerooney.
